It is currently Nov 30th, 2020, 9:17 pm Advanced search
Attn: Danny
Vendor forum for BMVWA. Look here for everything BMVWA related.
Attn: Danny
Postby Russell » Mar 7th, 2011, 4:34 pm
Are there any warranty issues with lowering my car? I'm only thinking about dropping 1" but I don't want to do it if it's going to be issues. Let me know.
Thanks,
Chris
EDIT: I should have put this on the BMVA section. Mods, could you please move this for me. Thanks!
2015 Golf 1.8T
Russell
Re: Attn: Danny
Postby Danny » Mar 7th, 2011, 5:47 pm
Chris,
There are no issues with lowering, especially if it is just a modest drop of 1".
Just a heads up (and this is common sense) but if you put aftermarket springs in the Jetta and there is an issue with them, the springs themselves will not be covered by VW warranty...you will have to go to whoever you bought them from. However, I think we can now get VW lowering springs for the new Jetta. Would you like me to check on that for you as well?
I hope this answered your question well enough.
BMVA
Danny
Re: Attn: Danny
Postby Russell » Mar 7th, 2011, 5:57 pm
That's great man! Can you check on those springs for me. Do you guys need to install them or can I do it?
2015 Golf 1.8T
Russell
Re: Attn: Danny
Postby lew » Mar 7th, 2011, 6:32 pm
Pffffff 1" drop :lol:
lew
Re: Attn: Danny
Postby Fenny » Mar 7th, 2011, 6:55 pm
A nice subtle drop and some nice wheels will look great.
You can do it yourself...shouldn't be hard if you have the proper tools. ie. spring compressor, strut spreader, I'm sure you'll probably need a triple hex bit as well but I'm not certain. Don't really know what bits and such the new jettas use.
Should be a piece of piss, just take your time. And don't forget to get a wheel alignment after you're done.
Fenny
Re: Attn: Danny
Postby Russell » Mar 7th, 2011, 7:40 pm
lewismartin wrote:Pffffff 1" drop :lol:
That's enough for around here isn't it? ;) I don't want to high center in a pot hole in my brand new car. :D How low is everybody going around here without beating up everything?
2015 Golf 1.8T
Russell
Re: Attn: Danny
Postby GTI » Mar 7th, 2011, 8:01 pm
1.5 to 2 is plenty Chris and even the 1 inch drop will settle overtime. Don't go too low if its a daily driver which I'm pretty sure it is see if danny has a sport spring upgrade
1984 Rabbit GTI
1983 Rabbit Cabriolet
Re: Attn: Danny
Postby Fenny » Mar 7th, 2011, 8:42 pm
Ask Karl, I think he's the lowest, then probably dubnut and then possibly myself.
I his subframe from time to time, and when you go over bumps my butt clinches but the car looks dope...lol :crazy:
I'm dropped about 3 inches from original height...I thought I bought a tiguan til I put the coilovers on... :D
Fenny
Re: Attn: Danny
Postby lew » Mar 7th, 2011, 8:44 pm
I'm just messing around, 1"is plenty for the roads in NL.
lew
Re: Attn: Danny
Postby Fenny » Mar 7th, 2011, 8:46 pm
Daily summer height
Fenny
Re: Attn: Danny
Postby Danny » Mar 7th, 2011, 9:16 pm
Sorry for the delay Chris, I just read your post. I will check in the morning on the update for the new Jetta springs. I assume they are available because the GLI's are on the way in.
I haven't witnessed the new Jetta taken apart yet, but I assume it's the same old routine. To swap the old ones you will compress the current springs, drop out the struts, swap springs, compress again and install them back up. After this your Jetta will require a wheel alignment to ensure you tires don't get eaten up.
I will PM you when I check on availability tomorrow in the AM.
BMVA
Danny
Re: Attn: Danny
Postby lew » Mar 8th, 2011, 12:03 am
Danny wrote:After this your Jetta will require a wheel alignment to ensure you tires don't get eaten up.
Truth
lew
Re: Attn: Danny
Postby vdubkarl » Mar 8th, 2011, 7:26 am
i bottom out once every couple of weeks....but i also have a fairly low car. it's a trade-off...a 1 inch drop on a new jetta will make a bigger difference than it would on a mk4!
vdubkarl
Re: Attn: Danny
Postby dubnut » Mar 8th, 2011, 8:21 am
vdubkarl wrote:i bottom out once every couple of weeks....but i also have a fairly low car. it's a trade-off...a 1 inch drop on a new jetta will make a bigger difference than it would on a mk4!
Pfft...every couple weeks? I usually do about once a day! And with the winter tires on now which are smaller profile, it's even worse, even after lifting it an inch or so in the front. Glad I got the FJ now. :)
But 1" is more than enough, especially if it's going to be used to transport your family around.
Bagged '08 GLI - K04 - APR Tuned
dubnut
Re: Attn: Danny
Postby vdubkarl » Mar 8th, 2011, 1:10 pm
I don't drive my car daily...plus I'm not chipped so I don't drive as fast haha
vdubkarl
Re: Attn: Danny
Postby Russell » Mar 9th, 2011, 11:25 am
Looks like H&R are the only guys making springs for the new Jetta as of yet. Gonna skip this process for this year due to some good advise from the local VW dealer.
Thanks guys!
Chris
2015 Golf 1.8T
Russell
Re: Attn: Danny
Postby lew » Mar 9th, 2011, 12:06 pm
Russell wrote:Will MKVI Golf/GTI springs work in my Jetta or are the spring rates totally different? Or size/diameter different? I have lots of questions! :D
Thanks guys!
Chris
You sir need to become one with http://forums.vwvortex.com all your questions are awnsered there.
lew
Re: Attn: Danny
Postby GLI » Mar 9th, 2011, 12:24 pm
Thanks guys!
Chris
but only after requisite responses to your thread of "learn how to use the seartch function" by the whoretex nazis.
I suspect the answer is yes as long as your mk6 is not a 2.0l which I think comes with the steel girder suspension system as opposed to the independant multi link rear on 2.5l and GTi / GLIs.
Dubless.
Once upon a time there were fox gti rabbit gli westfalia.
GLI
Re: Attn: Danny
Postby Fenny » Mar 9th, 2011, 12:31 pm
H&R are quality. Highly recommended by many, many people.
Fenny
Re: Attn: Danny
Postby Russell » Mar 9th, 2011, 12:39 pm
I've alrady signed up on the Vortex. I have done a lot of searching but, not much luck where the car is an all new model. I'll try for springs next year and just go with the wheels for this one. Thanks for the input guys!
Chris
2015 Golf 1.8T
Russell
Re: Attn: Danny
Postby GTI » Mar 9th, 2011, 12:42 pm
Did Danny come up with anything? H&R are good as are FK. I've used both.
1984 Rabbit GTI
Re: Attn: Danny
Postby lew » Mar 9th, 2011, 1:08 pm
I'm rolling H&R's and they are awesome, not a single problem after ~35k
lew
Re: Attn: Danny
Postby GTI » Mar 9th, 2011, 1:11 pm
1984 Rabbit GTI
Re: Attn: Danny
Postby T_Dub » Mar 9th, 2011, 1:19 pm
I'm gonna go sort of off topic here. The Jetta 6 base model has a 2.slo, and Jetta 4 suspension!?!?! WTF, thats nutty, no wonder its so cheap.
2015 GTI
2006 LR3
1977 Kawasaki KZ650-810cc
1974 Kawasaki H1 Mach III
T_Dub
Re: Attn: Danny
Postby lew » Mar 9th, 2011, 1:42 pm
T_Dub wrote:I'm gonna go sort of off topic here. The Jetta 6 base model has a 2.slo, and Jetta 4 suspension!?!?! WTF, thats nutty, no wonder its so cheap.
It doesn't have independent rear axle and has drum breaks in the rear too :thumbdown:
And Russell, stop completly editing your posts after people reply, its really confusing.
lew
Next
Return to Bill Matthews Volkswagen Audi
